2" P.A. body lift install
diablito
PostPosted: Mon Oct 23, 2006 8:10 am    Post subject: 2" P.A. body lift install Reply with quote
Just installed a 2" P.A. body lift on my 95 YJ 4.0 automatic, I sprayed all the bolts with PB blaster prior, I did the lift by my self, in my driveway, with hand tools, took 2 days, heres how it went, disconnect battery, slid rubber boot off on steering column, un-bolted radiator, un-bolted rear exhaust hanger, removed gas filler door/bracket, loosened all body bolts, none broke, installed passenger side, then drivers side pucks, re-installing the drop-down brackets on the radiator was a p.i.t.a. had to lengthen the transmission/gear linkage rod (welded 2"rod). replaced vacuum hose, lengthened the gas filler hoses, bent the rear exhaust hanger, notched the front plate holding the brake line. the steering column extended on its own. Found out my Jeep dosen't have the body bolt nuts welded in place, they are not nuts but threaded flat bar sitting in a welded box, check out the front body bolt nut? tightened everything up, test drove it, Overall not to difficult. Very Happy
