1988 Cherokee
rodneyjt24
PostPosted: Tue Oct 24, 2006 3:41 am    Post subject: 1988 Cherokee Reply with quote
1988 cherokee. Ran fine on the way home from work. Would not start the next morning. Tried to fool around with it to see if I could get some error codes. No help.
This is the weird part. If I put a jumper wire on #6 and #7 pin on the diagnostic connector the engine will start up and run fine. If I remove the jumper wire the engine stops. WTF?
Any help would be super. Thanks.
87Eugenejeep
PostPosted: Sun Nov 05, 2006 9:58 am    Post subject: Reply with quote
I have an 87 that may have the same problem, Can you send me a pict or post a pict of that so I can see and try it myself.
Thank you so much.
rodneyjt24
PostPosted: Mon Nov 06, 2006 2:53 am    Post subject: Reply with quote
Sure I can send a pic. In the meantime, what is going on with your 87?
