249 to 231 T-Case Swap
Jeepfleet
PostPosted: Thu Mar 09, 2006 12:55 pm    Post subject: 249 to 231 T-Case Swap Reply with quote
Just finished a 249 to 231 swap on a 96 4.0 ZJ. The doner case was out of a 98 4.0 XJ. Input bolted right up used the linkage in the ZJ and the shift tab on the 231. Speed sensor from the 249. The ZJ has a 3.5 Tuff Country lift. The Driveshaft was an inch too long so cut the outputshaft down an inch and the slipyoke down an inch, leaving 4.5 inches of spline engagment.(better than stock on the XJ) Didn't bother with the fwd light thing...
PostPosted: Thu Mar 09, 2006 9:40 pm    Post subject: Reply with quote
Cool... Thats works... I just made adjustable control arms and pushed the axle back to give the driveshaft room but cutting works to...
Good job... Any pics???
DankNesS
PostPosted: Tue Nov 07, 2006 6:48 pm    Post subject: Reply with quote
i have a 3.5 lift and very strongly want a 231 until i read this.. im not to comfortable cutting like that... swampy you made? adjustable control arms and the 231 went in no problem? what kind of 231 did you get? i have a 318 so the 4.0 231 wont work right?
