The 88 Cherokee finale!!!!!! Alive and well!!!!!!!!!!!!!
rodneyjt24
PostPosted: Mon Nov 06, 2006 8:50 am    Post subject: The 88 Cherokee finale!!!!!! Alive and well!!!!!!!!!!!!! Reply with quote
Here is what I did. I cleaned all major ground cable. I added a couple of extra ground to chassis and engine cables. Replaced camshatft, crankshaft and throttle position sensors. But nothing really got any better until I cleaned the ground cables and replaced the ignition control module. I can only say that the ICM was trying to pull negative/ground from some other place it should not have.........Chasis ground? Dont really know. So if you have this same or similar trouble, these would be stuff to check. Thanks to all who have replied. My 88 Is alive and well!!!!!!!!!!!!!!!!!!!
