Grand Cherokee Specs and FAQ
Goto page 1, 2  Next
PostPosted: Wed Feb 25, 2004 7:38 pm    Post subject: Grand Cherokee Specs and FAQ Reply with quote
Largest tires you can fit on a stock Grand are 30X9.5
With a budget boost you can fit 31X10.5 (some minor trimming.)
You need 3.5 to clear 32's (additional trimming ..Minor that is..)
4.5 will clear 33's (this will require some serious trimming..)
You need a long arm kit or at least full adjustable arms and 5.5 to clear 33's well without hardcore fender trimming..
Champion 9203's are hotter plugs for grands.. (VCool
Up grad Alt.. Out of some Limiteds and Dakota's with V8's
Number 5602........136 amps as oposed to the 90 amp stocker..
Any other items that you think should be addressed or questions that you have.. This is where to put them and I will add them to the list.
Also check the link in the other thread for tech on North American Grand Cherokee Association...
Any questions you can think to ask feel free..
PostPosted: Wed Jun 09, 2004 12:59 pm    Post subject: Reply with quote
WJ OEM part numbers
2006 Jeep Grand Cherokee Specifications
2007 Jeep Grand Cherokee Specifications
2007 Jeep Grand Cherokee SRT8 Specifications
PostPosted: Wed Jun 09, 2004 5:44 pm    Post subject: Reply with quote
Nice one... Mr. Green
PostPosted: Thu Oct 07, 2004 10:27 am    Post subject: Reply with quote
Dana Spicer Grand Cherokee WJ 44-4 Service Manual
jeepjaunt
PostPosted: Fri Dec 02, 2005 6:22 pm    Post subject: alt upgrade Reply with quote
a good alt for your grand would be one out og a dodge with a v-10 prefer a 3500 model. they're 160 amps and they bolt right in!!
PostPosted: Wed May 10, 2006 1:16 pm    Post subject: Reply with quote
Transmissions
545RFE 5 spd. automatic transmission used in the 2001 - Current Model Jeep Grand Cherokee 4.7L engines
45RFE: 4 spd. automatic transmission used in 1999 - 2000 Jeep Grand Cherokees with 4.7L engines.
46RE: 4 spd. automatic transmission used in 1998 Jeep Grand Cherokees with 5.9L engines.
44RE: 4 sd. automatic transmission used in 1996 to 1998 Jeep Grand Cherokee's with 5.2L engines.
42RE: 4 spd. automatic transmission used in 1993 to 2002 Jeep Grand Cherokees with 4.0L engines.
46RH: 4 spd. automatic transmission used in 1993 to 1995 Jeep Grand Cherokees with 5.2L engines
AX-15 5 spd. manual transmission used in 1993 - 94 Jeep Grand Cherokees with 4.0L engines.
nori
PostPosted: Sat Mar 03, 2007 3:20 pm    Post subject: Re: Grand Cherokee Specs and FAQ Reply with quote
Champion's website didn't list 9203 as part of the option for my V8 5.2L orvis.
http://www.championsparkplugs.com/results_app.asp?AAIA=1182158
Is it still ok to use 9203 for my grand? Thanks.
PostPosted: Sun Mar 04, 2007 7:51 am    Post subject: Reply with quote
I think it was meant to say 9201. Personally, I use the Champion Truck Plugs 4071 in my ZJ. They work great for me. I use the truck plugs in all my JEEPS.
83 CJ7 4.2, 88 XJ 4.0, 94 ZJ 5.2, 99 XJ 4.0
UNDERGROUND JEEPS
nori
PostPosted: Sun Mar 04, 2007 4:36 pm    Post subject: Reply with quote
Thanks again Orange. I'll definately look into the iridium ones and truck plugs on my next change. I just replaced mine with the same champion plugs type that came with the car when purchased, so far, so good.
drew42
PostPosted: Wed May 16, 2007 11:24 am    Post subject: Reply with quote
I tried looking for the 9203 plugs , and the only number they had listed was 9202 . Was there a number change ? Cuz I would like to go with the plugs that you guys recommend. Confused
Black on Black , V8 , Killer Chrome ,and Smokin' . And I have 5 dollars on a case of beer !
PostPosted: Wed May 16, 2007 3:45 pm    Post subject: Reply with quote
Drew, you have a WJ with 4.7 those numbers are for ZJ's with 5.2. On the WJ, 9202 is the right number for the Champion Iridiums and 4318 is the number for Champion Truck Plugs. Very Happy
.040" gap for WJ 4.7
.035" gap for ZJ 5.2
UNDERGROUND JEEPS
drew42
PostPosted: Thu May 17, 2007 4:17 am    Post subject: Reply with quote
You guys are getting me teary -eyed Crying or Very sad . Anytime that I needed help you were there for me Very Happy . Thankx Orange , I am still taking notes and pretty soon I will be as on-top of it as you guys are Mr. Green .
PostPosted: Thu May 17, 2007 6:50 am    Post subject: Reply with quote
No problem bud!!! Cool
UNDERGROUND JEEPS
erizzo123
PostPosted: Sun Jul 01, 2007 7:43 am    Post subject: Reply with quote
who is this orange guy he is a real fanatic. he deserves some real credit! Mr. Green
PostPosted: Wed Nov 19, 2008 8:05 pm    Post subject: Reply with quote
ZJ Tranny, Gearing, & T-case Info
Year.....Engine.......Tranny.......Rear........... Gearing..............TC
93-95.....5.2..........46RH.......Dana 35.........3.73.................249
.............4.0..........42RE.......Dana 35.........3.73 w/tow........242/231/249
Early 93...........(Some 4.0 Have AW4).......3.55 non tow....242/231/249
93-94...........(Some 4.0 Have AX-15 Manual Trans.)
96-98.....5.2.........44RE........Dana44A........3.73 .................249
.............5.9.........46RE........Dana44A...... ..3.73.................249
.............4.0.........42RE........Dana35....... ..3.55 non tow...242/231/249
.................................................. .........3.73 w/tow......242/231/249
TC OPTIONS
249 is a full time 4wd case
Always in 4wd
Shift Pattern 4 – n – 4low
93-95 have no low lock
96-98 have low lock
231 is a part time case
4wd should be used ONLY in very slippery situations
Shift Pattern 2wd – 4 pt – n – 4low
4 part and low lock the front wheels to the back wheels
2wd only back tires get power
242 is a full time 4wd case
4 full time can be used at anytime even dry pavement
Shift Pattern 2wd – 4pt – 4ft – n – 4low
4 full allows there to be a slight variation in power separation so turning will not destroy your case
TRANNY TIME
42 RE
4 = 4speed, 2 = strength, R = Rear wheel drive E = Electronically controlled
44 RE
4 = 4speed, 4 = strength, R = Rear wheel drive E = Electronically controlled
46 RE
4 = 4speed, 6 = strength, R = Rear wheel drive E = Electronically controlled
46 RH
4 = 4speed, 6 = strength, R = Rear wheel drive H = Hydraulically controlled
UNDERGROUND JEEPS
Goto page 1, 2  Next
Page 1 of 2
