94 Wrangler engine question
Heavyshadow
PostPosted: Tue Nov 07, 2006 9:38 am    Post subject: 94 Wrangler engine question Reply with quote
Hi everyone, I have a '94 wrangler 2.5L 4 cyl auto and the engine just died. I found a simalar engine on ebay but it's from a comanche. My question is would a 2.5L comanche engine work in a wrangler? Thanks in advance for your help.
EDIT: After looking around online, I'm thinking of buying a remanufactured engine from Rhino. Has anyone ever used one of these, and if so, how are they?
Tardis
PostPosted: Sat Nov 11, 2006 9:26 am    Post subject: Re: 94 Wrangler engine question Reply with quote
The Comamche 2.5 will fit as long as it's a 91-92. The interchange for 2.5L w/port fuel injection is:
91-95 Cherokee/Wrangler
91-92 Comanche
I don't trust remanned engines from anywhere. They recycle parts from several engine cores to make one good one. You can do the same thing at home for way cheaper. If your current engine isn't totally blown up with spun bearings, a cracked block etc, then rebuild it. You'll be ahead in the long run, with a good running engine that you put together yourself.
98' TJ, 99' XJ
