Post subject: squeal in 4th and 5th gear
jeepy100
PostPosted: Tue Nov 07, 2006 4:59 pm    Post subject: Post subject: squeal in 4th and 5th gear Reply with quote
Posted: Tue Nov 07, 2006 7:16 pm Post subject: squeal in 4th and 5th gear
Hi I am new so please bear with me. Checked all the fluids. Sounds like from transmission but transmission man said from diff. Pulled rear driveline and put in 4wd and it did not squeal. If you push in clutch it stops. Check bearing in rtansfer case fine. No really excess play that I can notice. Thanks for any suggestions
PostPosted: Wed Nov 08, 2006 2:41 am    Post subject: Reply with quote
Does it change with your speed? When you turn?
