Rear Differential trouble
Post new topic   Reply to topic     Forum Index -> Liberty Forum
cliffords
PostPosted: Sun Jul 15, 2007 2:39 am    Post subject: Rear Differential trouble Reply with quote
Hi
Here in the Uk I have a 2.8crd Auto Cherokee, with 40k miles covered from new. It has just passed 4 years old and has had all dealer servicing.
I have noticed when pulling away from a junction especially after a long run at speed the back end feels as if it is slightly grabbing for grip , almost as though the wheels are slipping on the road for a second.
This happens with slight turn on the steering in two wheel drive only.
The main dealer has added more friction modifier, this cured it for about 1 week, now it has returned.
Has anyone had a similar experience and if so with any cures known?
Is this 'chatter' as I have heard it described.
thanks
PostPosted: Sun Jul 15, 2007 8:00 am    Post subject: Reply with quote
Try throwing some Royal Purple or Redline in it.
cliffords
PostPosted: Sun Jul 15, 2007 8:17 am    Post subject: Reply with quote
Can you be any more specific on which product to use ?
Is this a known/common problem ?
Thank you
PostPosted: Sun Jul 15, 2007 12:18 pm    Post subject: Reply with quote
Did they service the differentials (change the gear oil)? If not than is should be expected. You're supposed to change the gear oil every 30,000 miles.
Click these for specific product use. There are other brands out there also!
Red Line
Royal Purple
cliffords
PostPosted: Sun Jul 15, 2007 12:30 pm    Post subject: Reply with quote
Yes I have had the diff oil changed twice during the 40k miles.
I will try one of these, thank you.
nzoliver
PostPosted: Fri Feb 06, 2009 12:59 pm    Post subject: Reply with quote
Hi,
Just had the same here.
I had it drained and refilled by the dealer with the Mopar additive and synthetic oil. All good now after 60 ish miles of driving.
They did tell me that as the oild gets old the additive does too and gets less effective. Confused
Funk-49
PostPosted: Thu Apr 02, 2009 4:52 pm    Post subject: Reply with quote
I have a 96 I bought used this fall and had the same problem. Not Knowing where it was in terms of regular maintenance I drained mine (which looked pristine) and went back with the Royal Purple. It seemed to improve slightly, but its still there. I'm wondering if their may be some slack in my u-joint, but highway ride etc. seem fine.
There are no stupid questions, only stoopid people.
Post new topic   Reply to topic     Forum Index -> Liberty Forum All times are GMT - 8 Hours
