Winch Specifications for Advanced Winching Techniques
Club Moderator
PostPosted: Thu Feb 26, 2004 2:14 am    Post subject: Winch Specifications for Advanced Winching Techniques Reply with quote
Many of us have winches and many of us have winched out of some tough spots. Here are some specifications that I find interesting. I am pulling most of this from the lastest (March) issue of Four Wheeler magazine.
A winch's maximum (rated) pulling power is only available when the rope is pulling directly from the drum. As more layers are added, the capacity decreases significantly. I have listed two tables below, one for 8000 lb winches and one for 9000 lb winches.
Drum Layer= 8000 lbs__________9000 lbs
(100% of rated capacity)
2nd Layer = 6800 lbs__________7650 lbs
(85% of rated capacity)
3rd Layer = 5760 lbs__________6480 lbs
(72% of rated capacity)
4th Layer = 4960 lbs__________5580 lbs
(62% of rated capacity)
5th Layer = 4240 lbs__________4770 lbs
(53% of rated capacity)
These specs should be accurate within 5% on all winches.
Different types of winch rope also affect the rated capacity of your winch.
Wire Rope
7 X 19 Galvanized Cable
3/16" = 4,200 lbs
1/4" = 7,000 lbs
5/16" = 9,800 lbs
3/8" = 14,400 lbs
7 X 19 Stainless Steel Cable
3/16" = 3,700 lbs
1/4" = 6,400 lbs
5/16" = 9,000 lbs
3/8" = 12,000 lbs
Synthetic Winch Rope
3/16" = 5,400 lbs
1/4" = 9,200 lbs
5/16" = 13,700 lbs
3/8" = 20,400 lbs
All specifications are listed for comparison only. Actual operating loads may vary, but should never exceed recommended design factor or 20% of catalog breaking strength.
Bottom line - understand your gear and it's limitations, maintain it well, replace when worn, and treat it as lethal, and you're much more likely to have an effective and SAFE winching experience.
Back from the Dead??
